Topic: PartyMix 2 - Problem changing effects pads function
I have a Numark PartyMix 2. I wanted to change which effects are on one of the pads since it only has 4 pads and I don't need both Flanger and Phaser. So I went into the Pads Editor and swapped the code in the Push Action window between pad 3 (Phaser) and pad 7 (Echo).
E.g. now Pad 3's Push Action code is: effect_active 'Echo' ? effect_slider 'Echo' 2 50% ? effect_active 'Echo' : effect_slider 'Echo' 2 50% : effect_active 'Echo' & effect_slider 'Echo' 2 50%
This hasn't worked out like I thought it would! Now when I hit pad 3 I do get the Echo effect but both pad 3 and pad 7 are highlighted. And when I hit pad 7 I do get the Phaser effect but the pad does not get highlighted at all.
I am clearly missing some understanding of how this system works. Any help would be appreciated.
geposted Fri 07 Oct 22 @ 8:44 am
Nobody knows?
Any suggestions on how I can solve this then?
Not sure why your script is so complex.
Doesnt this work for you ..
Anyways, the issue here is that this special Pads page has some query="" internal actions and can only be edited via the xml.
Since you already edited the Pads page, you should have a file PML FX.xml in /Documents/VirtualDJ/Pads folder.
Open the file with some advanced Editor (like Notepad++) - avoid Web Browsers - and edit the query="" part of the Pad you wish to edit.
But still , you need a much simpler action.
go into the pad xml [text editor level], delete the query entry for pad 7
save the xml & restart vdj
Pad LED logic has a "hidden layer" at text editor level for certain LED logic cases
@djdad, that's how the PML fx page is as default
I didn't write that script. It is what was on Pad 7. I just copy and pasted it to Pad 3. The pad layout is generated when I plug in the controller.
I'll check out this XML page to see if that sheds any light - thanks.
great, thanks. This solved it. I deleted the entry in the XML file and then recreated the script in the Pad Editor and it appears to be working as expected now.
