Topic: Same equalizer setting for each decks
Hello, I want to set same equalizer setting for each deck. For example; I set EQ setting for deck1, when i mix the deck 2, EQ setting is changing as default setting. Does It make possible, how? Thanks in advance.
geposted Sat 08 Oct 22 @ 9:03 am
To do that it's probably better to use an EQ as master effect. That will stay at the same throughout your mixing
The deck eqs are really supposed to be used/changed while mixing 2 tracks
