Hello. I'm getting this when using 'list Year range 10' on Instant filters.
Also, the same behavior on Filter Folders using ''group by Year range 10'
Why's that?
Why's that?
geposted Wed 19 Oct 22 @ 1:16 am
It's by design. The last decade is grouped/split by 1 year and the one before that by 5
If for some reason you dont like this, you could create your own Decade Filters using < and > operators with specific year values
geposted Wed 19 Oct 22 @ 12:56 pm
Alright, thanks for the explanation DJDAD, although I find that design a little wierd and doesn't fullfill my needs.
I tried to make it work in Instant filters the way you suggested but that way defeats the purpose of an instant search using just a button since I have to create one filter per decade so it's easier just making a standard filter folder.
Thanks anyway.
Thanks anyway.
geposted Thu 20 Oct 22 @ 3:16 am
