I'll try to put my question here.
Since a few days I have the Numark NS4FX controller. The support of VDJ out-of-the-box is exemplary.
I tried to use the filter select buttons (FX SELECT) with SHIFT to access filters or effects other than the pre-selected ones.
I noticed that when I pressed SHIFT+HPF, the command SHIFT_FX_LPF was called.
SHIFT+LPF as well as SHIFT+ECHO do not call any command.
SHIFT+REVERB calls SHIFT_FX_ECHO.
Only SHIFT+FLANGER and SHIFT+PHASER work correctly and call SHIFT_FX_FLANGER as well as SHIFT_FX_PHASER.
Can this assignment be changed/corrected only by Numark? Or are there also possibilities on the part of VirtualDJ/Atomix?
Is this assignment hard-coded?
geposted Fri 21 Oct 22 @ 8:30 am
