It is quite FRUSTRATING that magically ALL MY LOOPS disapear after the "NEXT" update was finish...
... and it's even more ironic that the "save loop" option in the Virtual DJ... DOESN'T WORK ANYMORE after restarting the app...
... ok dev, I know that you were trying to "manage" things and glitch... but there... that's more than just a glitch : it's an ERROR! It's not like if I have more than 40 or 50 loops "previously" registered, but c'mon... that's just disgusting...
(PS : SAME PROBLEM WITH THE "HOTCUES"!!!)
geposted Mon 24 Oct 22 @ 3:34 pm
It's not a general bug
But it's pretty simple to look into and possible fix on your laptop
They get saved to the database file
So either your laptop can't save to the database.xml file, og you are somehow locking the file, usually do to an old hanging VDJ session
Usually a laptop reboot fixes it. If not, bring the database.xml file back from your backup (if you haven't set that up to auto-backup, now is a good time to do it)
And if you feel it may be a file rights issue, the checkup this guide:
https://www.virtualdj.com/wiki/Settings%20not%20saving.html
geposted Mon 24 Oct 22 @ 4:39 pm
