The title and artist appear in the tracklist.txt file but not all times in the m3u file.
How can I ensure that all titles and artists are included in the m3u file?
geposted Tue 25 Oct 22 @ 12:35 pm
Artist and Title are only written to the m3u if they are coming from the tag of the file.
If they are parsed from the filename, then they are not included, since the filename itself is already present.
So if you have a program that wants to use VDJ-specific comment tags in m3u files, the correct way to handle it is to parse the filename and extract artist/filename from there if no artist/title is present in the comment tag.
geposted Tue 25 Oct 22 @ 1:35 pm
The problem is that some mp3 files that do have a title and artist tag don't show this data in the logs.
The tags are also well read and are listed under the edit box in the editor. Too bad I can't add an mp3 file, otherwise I can provide some good mp3 files with tags that don't show up in the logs. I think this is a bug!
geposted Tue 25 Oct 22 @ 2:23 pm
