Mine is just a suggestion. The "filter" set as PITCH is great, but it would be perfect if its zero value / position respected the harmonic key currently in use. Unfortunately, as it is, the result is often traumatic as soon as you touch the knob. The Pitch currently "resets" the harmonic key to the original value causing an unpleasant result during the mixing phase. Thanks for your attention. :)
geposted Wed 26 Oct 22 @ 10:48 am
+1
geposted Wed 26 Oct 22 @ 10:50 am
That's true - it jumps back to original key as the first thing, when you move the pitch color FX on the filter
I never noticed that :)
geposted Wed 26 Oct 22 @ 1:06 pm
+1
geposted Wed 26 Oct 22 @ 5:35 pm
"PICTH "filter" could works better "...so could grammar & spell checkers.
Try the veal...
Try the veal...
geposted Wed 26 Oct 22 @ 6:12 pm
Try the veal...
Try the veal...
I'm simply Italian, so mine is a school level English. Your intervention is simply useless and out of place.
geposted Mon 31 Oct 22 @ 10:12 am
There has been worked on it in the latest Early Access release
From the release notes:
"-Pitch effect remembers manual pitch changes (due to autoKey for example)"
geposted Thu 03 Nov 22 @ 3:50 pm
WONDERFUL!!! I will try tonite in my show <3 thanksssssssssss
geposted Thu 03 Nov 22 @ 6:48 pm
