file system naming order:
1, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 2, 21......
i cannot believe a $200 program does not use numbers to order file names. just sad
geposted Wed 26 Oct 22 @ 11:08 pm
that's alphanumerical order, [well 2 after 20 is a typo I suspect]
we humans parse a leading zero but vdj sorting of artist/title/filename has to deal with every possible case, it can't guess a leading zero, because natural sorting [after 1 comes 2 not 10] leads to unresolvable issues in edge cases.
artist/title/filename uses strict alphanumerical order,
track number field however does imply a leading zero.
so use track number field or add leading zeros to the tags.
I can't find the post but phantomdj explained it better than me.
geposted Thu 27 Oct 22 @ 2:09 am
          Ah I found it
    PhantomDeejay wrote :
       Just FYI, Windows are using what's called "natural" sorting, while most apps (including VirtualDJ) are using what's called "strict" sorting
To give you an example,
Windows will sort like this:
1
02
3
4
05
10
However most programs will sort like this:
02
05
1
10
3
4
The first approach feels more natural to humans but technically speaking is not correct
The second approach is technically correct (even by grammar/syntax terms) but doesn't feel natural because your mind interpets the "text" as numbers and wants to sort them by a "smaller to bigger number" rule.
1
02
3
4
05
10
02
05
1
10
3
4
geposted Thu 27 Oct 22 @ 2:30 am
