Topic: Leaving In-Line Comments Along VDJ Script?
Is there a way to leave your own comments alongside your VDJ scripts like you can do with most programming languages?
For example, I created a button which sets the zoom level of the waveform to where I like it and wanted to leave a comment saying # my preferred zoom level.
I just don't know which symbol I can use to differentiate comments from codes.
Also, is it possible to see your current zoom level percent?
geposted Fri 28 Oct 22 @ 9:03 pm
imagine a custom button, name it [backticks included]
`zoom`
as for comments, if it's not real script vdj will ignore it, so you could write a script and at the end you could do something like this
zoom & "this is usually 0.4"
geposted Sat 29 Oct 22 @ 3:14 am
Great. Thanks!
geposted Tue 01 Nov 22 @ 2:28 am
