Hey all.
I guess more people mentioned this but i am not sure if any solution was found.
My virtual dj is freezing randomly for 2-3 seconds and then continues playing on my Macbook Pro. I tried a few earlier versions but eventually gave up and started using it on the windows partition of the Mac (on an earlier version, i think the 6503 or the one before that) which made it worked better in general. it froze maybe once or twice since then.
Anw the point is if i have a Macbook i dont really wanna use it with Windows so any solution to this issue? Maybe the mac is too old to handle it? Even though i saw people complaining about the same issue on newer machines so age shouldn't be the issue. Math Engine is off.
I am using a Macbook Pro 2014 with 8gb ram and an i5 and Virtual DJ Pro Infinity 2021 (tried different versions of it but no solution)
Thank u guys
Thank u guys
geposted Sat 29 Oct 22 @ 9:04 pm
