i want to know how many laptops can i install the program buying 1 licence?
thanks in advance.
thanks in advance.
geposted Tue 01 Nov 22 @ 7:36 pm
Short answer; Performing one machine for live, one machine as a backup at one venue.
Detailed answer;
Since logging in unlocks pro features, and a unlogged machine is the same as having a home licence [free] there are no restrictions on the number of machines you can install vdj on.
You could have vdj installed on as many machines as you wish, but your login will only allow 2 machines to be unlocked with pro features at any one time.
Detailed answer;
geposted Tue 01 Nov 22 @ 7:55 pm
thanks for your quick response,.
i mean, how many laptops can i use with dj controller with 1 virtual dj pro infinity licence? ( i know with the free version is unlimited but i mean using laptops with dj controller or console )
thanks in advance.
thanks in advance.
geposted Wed 02 Nov 22 @ 8:32 am
In simple terms two.
geposted Wed 02 Nov 22 @ 8:35 am
Then i can use licence in 2 laptops with dj controller right?
Thanks all of you for your help.
geposted Thu 03 Nov 22 @ 9:19 pm
