Hi !
On the Pioneer DDJ 1000 the beat effect 'low cut echo' switches to 'HP filter' when you connect it to VDJ.
Does anyone know how a can change it to a 'vinyl brake effect'?
Many thanks in advance !!!
geposted Thu 03 Nov 22 @ 10:08 am
<map value="FX_SEL_LOWCUT" action="deck master effect_select 'filter hp' & effect_select 'sampler' 'filter hp' & deck all effect_select 'brakestart'" />
geposted Thu 03 Nov 22 @ 11:14 am
Na se Kala PhantomDeeJay !
Unfortunately i must be doing something wrong, when i go into mapping and find the low cut echo button, i copy, pasts over the actions with your code.
When i do this the low cut echo becomes another echo effect.
geposted Thu 03 Nov 22 @ 7:45 pm
(Copy/Paste friendly version, in case you didn't copy something right before)
geposted Thu 03 Nov 22 @ 9:54 pm
Great, that works !
But it still shows 'FILTER HP'
Can we do anything so it shows 'BRAKESTART'?
Thank you
Thank you
geposted Fri 04 Nov 22 @ 4:34 am
