Forum: Wishes and new features
Topic: VST3 folder .
Hi .
When I enter a VST3 folder in the options, Virtual DJ creates a folder named VST in the FX dropdown window.
But now it is the case that I also use VST2 effects.
The problem is that Virtual DJ then creates 2 folders called VST. It would be good to change it so that Virtual DJ creates a folder called VST3 for VST3 effects.
Then you know which VST2 and which VST3 are.
Otherwise you can no longer distinguish it .
Greetings Dani
geposted Thu 03 Nov 22 @ 2:01 pm
You could rename your VST folder to VST2 ;)
geposted Thu 03 Nov 22 @ 2:42 pm
Thanks .
I would have known that myself.
But it would still be useful if the program could distinguish it by itself ,
And VST3 would be at VST3 FX.
Some effects appear twice and you don't know if they are VST2 or 3 effects.
This is not good and confusing.
Thanks .
Have a nice evening .
geposted Thu 03 Nov 22 @ 4:51 pm
