Playing Spotify on my DJ computer is just fine. But once I open Virtual DJ , the Spotify sound stops. Is there a way around this issue?
I’m using my RMX controller as the sound output.
geposted Fri 04 Nov 22 @ 8:04 pm
turn off exclusive audio access
if you have it on so you can adjust latency of your controller that will go back to default
geposted Fri 04 Nov 22 @ 8:30 pm
Go in the Virtual DJ Audio Setup and toggle the Output from Asio to WASAPI. The Audio Latency i slower than. But you can use parallel other Aplications with your Soundcard.
geposted Tue 08 Nov 22 @ 7:07 pm
Just curios, AFAIK Spotify stopped supporting VDJ some time ago. How are you still using it on VDJ?
geposted Fri 18 Nov 22 @ 3:32 pm
The OP is using it from the web browser, not VDJ.
geposted Fri 18 Nov 22 @ 3:48 pm
