I thought the sync button is enough to help with beat-matching.
As per title, please, how do I disable automatic match/adjustment of tempo while I move the slider on the other side.
I think this is a bit crazy as it would be difficult to drop a different style or tempo of music with this automatic setting (maybe I clicked something?).
Also similarly how do I desable the automatic snapping to first beat-match when pressing play. This is also a bit crazy because if you start with some words/lyrics just before the beat it's getting skipped to the next/first beat when you press play even when your cue is set a qurter of half beat before that.
geposted Sat 05 Nov 22 @ 11:03 am
geposted Sat 05 Nov 22 @ 1:25 pm
