I just bought a 1000 SRT and noticed that the jog wheel will not scratch when using deck 1. It will scratch ok using deck 3. Jog wheel scratch is working ok on decks 2 & 4. This has been the same issue since I got the desk a week ago.
I also have Serato DJ and when I try using the jog wheels to scratch on that software, I can scratch on all the decks ok. So the problem must be bug or setting in Virtual DJ that is not allowing deck 1 to scratch. Computer and controller have been restarted many times and same issue.
I am using Virtual DJ version 8.5-64 b7235
Any ideas?
Thanks,
Dale
Any ideas?
Thanks,
Dale
geposted Sun 06 Nov 22 @ 5:14 pm
assuming pro skin, see 2 for pro skin
https://www.virtualdj.com/manuals/virtualdj/interface/decks/deckbasics.html
geposted Sun 06 Nov 22 @ 6:26 pm
Thanks.... going into Virtual DJ on my computer and clicking on Vinyl resolved the issue.
Dale
Dale
geposted Mon 07 Nov 22 @ 12:02 am
