Topic: tempo / pitch and efx fader on left side not going to 100%
geposted Mon 07 Nov 22 @ 4:52 pm
The min/max is dependent on your range setting
geposted Mon 07 Nov 22 @ 5:06 pm
How would i adjust the range setting for the entire left side of the deck nearly?
the photo shows that i cannot take the tempo slide all the way up to pick up the control . the hardware slider is all the way up and should be in the same position as the ui slider. It's not just the tempo slider it is also the efx knobs
geposted Mon 07 Nov 22 @ 5:11 pm
Digging deeper i found that both the efx knob and tempo slider are short on the negative value by 17.
This photo shows the efx knob 3 turned all the way to the right and the tempo all the way up ( slower)
geposted Mon 07 Nov 22 @ 6:19 pm
