Forum: VirtualDJ Skins
Topic: Ü Ö Ä in my Skin
Hi,
when i use special Character (ü ä ö ß ±) on Textzones in my Skin it always display a "?"
I edit for a test the default Skin and the Characters was display correct.
What is the problem on my Skin?
I use "Arial" similar to the default Skin.
geposted Tue 08 Nov 22 @ 9:17 pm
I have already tried the unicodes in the past.
This also doesn't work.
then try "ü"
and "Speichern unter, Codierung: UTF-8 mit BOM"
Is your text editor set to save in utf8?
@wollerosekauf @adion.
Thanks "UTF-8" was the problem. My code was in "Ansi Western Europe"
What is the right "UTF-8"? BOM or no BOM. It works both.
I have read this on the Developers Site but i given no attention. Shame on me...
No need for BOM
