Topic: Failure of auto-updates
A couple years ago I was given early access to the Rane One release update to test that out. Ever since then VDJ has never auto-updated for a regular or early release. It's been time enough I'd like to try to find a fix for this.
This originally started as a Intel based install and now I have both the M1 and Intel latest public releases. This lack of update is affecting both machines which leads me to believe there may be a flag on the account to not push updates to it (maybe because of the early release I had back in 2021 when the Rane One came out).
Any assistance would be great! :)
geposted Sun 13 Nov 22 @ 7:01 pm
There is no flag on your account, but you can check in Settings->Options->EarlyAccess.
If you set it to yes, restart VirtualDJ, and wait a few seconds to let it download (without playing a song), it should give you a message about the new update available.
Anothyer option would be to simply download and install the latest version directly from the site. You don't need to rely on auto-updates.
So I finally was able to get it to update in-app. But it was a bit weird. I ended up having to flag both auto updates and early access as no, full reboot. Restart the app, flip the flags again. Restart. And finally it took.
