Hi,
Congratulations, STEMS 2.0 sound incredible and work fine in REAL TIME on my MAC M1.
But if i prepare STEMS in advance :
Memory go to 1 Gb. .... 4. GB .....; 10 gB ..... 20 gB and after that the application STOPS
when i use STEMS in fly without saving them : fine
Preparing or exporting in CDJ : same problem as if memory cache is not cleaned between each prepared STEMS track.
Easy to reproduce : use a MAC M1, V7333, VENTURA, and choose a playlist with more than 100 track, and prepare STEMS , wait and see the memory go to 1 gb to 20 gB or more and the application stop.
hope it's help.
Anyway : bravo for new STEMS AI model.
Regards,
Olivier F.
hope it's help.
Regards,
Olivier F.
geposted Mon 14 Nov 22 @ 11:45 pm
this has been fixed, a new build will be available later today or tomorrow
geposted Tue 15 Nov 22 @ 9:20 am
Hi,
Virtual Dj support is like lighting speed.
Many thanks :)
Olivier F.
Many thanks :)
Olivier F.
geposted Tue 15 Nov 22 @ 9:22 am
You can try already here: https://download.virtualdj.com/mac7335.zip
Let us know if it does fix the problem for you
geposted Tue 15 Nov 22 @ 9:24 am
Gonna try to precompute a batch on my wife's M1 later today. Will report back if any issues.
geposted Tue 15 Nov 22 @ 10:04 am
Hi,
Tested 7335 on MAC M1 - 8 gb - with more than 100 track : auto prepare stems or CDJ export : fixed
Many thanks :)
Memory management is now ok
Regards,
Olivier
Many thanks :)
Regards,
Olivier
geposted Tue 15 Nov 22 @ 10:30 am
olivier REMUX wrote :
Hi,
Many thanks :)
Regards,
Olivier
Many thanks :)
Regards,
Olivier
But there is a new bug in 7335 :
when you have several prepared stems, and you select precomputed saved stems, when you select other stems to play, ths old is deleted in stem list. Saved Stems disapear randomnly.... without deleting. so you have to precompute again them... strange.
To reproduce : prepare two stems , save them, and with your controller load one and the second several times with the pusch button (donc with my DDJ1000) and precompute saved stems are deleted.
geposted Tue 15 Nov 22 @ 12:55 pm
Should be fixed here: https://download.virtualdj.com/mac7337.zip
geposted Tue 15 Nov 22 @ 1:45 pm
Hi,
7337 is a good isoteric number for a standard version :)
Just tried : perfect - fast support
now memory is perfect (less memory usage than other Dj software even with stems )
and precomputed stems perfect too :)
many thanks again :)
Olivier F.
Olivier F.
geposted Tue 15 Nov 22 @ 2:48 pm
Ist das Problem nur beim Mac?
geposted Tue 15 Nov 22 @ 3:59 pm
Hello Stephane,
A great review here :
https://www.youtube.com/watch?v=3pgxUevIvao
Bravo :)
geposted Tue 15 Nov 22 @ 4:34 pm
