Topic: how to modify loop_pad_pages?
My controller has 4 performance pads and I would like to be able to create loops of 16 or 32 beats with the pad buttons, however none of the pages offer that option in the first 4 pads. Is there a way to edit the pad_pages?
geposted Thu 17 Nov 22 @ 7:16 am
That's weird, unless you have edited the Loop pad page in the past, the default page should be "auto-adjusted" in order to reach 32 beats loop for controllers with 4 pads.
You are not using any additional controller at the same time, just the 4-pads one, right ?
Anyways, you can still edit the Loop page and for the first 4 pads (Push action and Name) have ..
loop_pad 5 .. to loop_pad 8 (instead 1 to 4)
geposted Thu 17 Nov 22 @ 2:48 pm
