hello
i have a xdj rx2. And everything is working with vdj. Ecxept my fx 1 and 2. I can see them change on the software but they dont work. my fx master works normaly.
WHen i put the hardware mixer mode on, my fx are all working but the soundlevel drops verry hard.
IS this normal?
IS this normal?
geposted Mon 21 Nov 22 @ 10:59 am
By Fx 1, Fx 2, you mean when the FX ASSIGN is in positions 1 and 2 (Nr .22 from here.. https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx2/layout/mixer.html ) ?
geposted Mon 21 Nov 22 @ 1:40 pm
yes. i can see them change in the software, but nothing happens. only if i put in on master i can hear thr effect running
geposted Wed 23 Nov 22 @ 1:10 pm
Most likely you haven't applied the correct Audio Setup, depending on the Mixer Mode your device is set to.
https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx2/mode.html
Also, read how the BEAT FX section works on each mode.
The Mixer mode is changed from VirtualDJ Settings->OPTIONS->CONTROLLER sub-category when the XDJ-RX2 is connected.
geposted Wed 23 Nov 22 @ 7:13 pm
PeterChepers, are you talking about the difference between the master output level when changing between Midi and Hardware mode on the RX2?
geposted Thu 24 Nov 22 @ 2:47 pm
