Hello!
I want to implement the same task as described in this topic:
https://www.virtualdj.com/forums/246170/VirtualDJ_Technical_Support/Send_midi_note_from_VirtualDJ_to_Cubase_via_LoopBe1__Help_please_.html
I did exactly as described, but loopMIDI does not receive commands from VDJ when I press one of the programmed PADS in the CUSTOM section - although when VDJ starts, loopMIDI receives some data from VDJ
@ARTDECHO
@LOCODOG
Hope you'll see this post, fortunately I can't find way to send you a personal message through this forum.
My goal is to send a command to change the scene in the RESOLUME ARENA during the playback of the track via POI
Thank you in advance
@ARTDECHO
@LOCODOG
geposted Mon 21 Nov 22 @ 1:50 pm
It might be a home user limitation. I'm not sure.
geposted Mon 21 Nov 22 @ 2:36 pm
Hello LOCODOG, nice to see your reply!
this is not the account that is used in VDJ to connect. Other controllers are working fine.
Any other idea?
Here's the screenshots of all setup:
https://drive.google.com/drive/folders/1IAwK68Ou9XrpJ4AAM5SaNBGsfJP3D3yM?usp=share_link
Any other idea?
geposted Mon 21 Nov 22 @ 6:32 pm
it's pretty horrible to fault find, [generally as a topic, plus navigating screenshots offsite] drivername looks different, that's the first thing I see.
geposted Mon 21 Nov 22 @ 7:33 pm
@LOCODOG I have a proposition for you.
Could you please contact me - details on the new screenshot in the link I posted earlier
geposted Tue 22 Nov 22 @ 5:57 am
no I'm not contacting you on telegram, if you have a licence just pm me.
geposted Tue 22 Nov 22 @ 6:10 am
You can also use this guide here: https://www.virtualdj.com/forums/218737/VirtualDJ_Plugins/The_Advanced_Freestyler_integration_thread.html?page=1
You can actually download the files and instead of using Freestyler, use your DAW on the other end.
You'll just have to pick the right MIDI notes.
If you open the XML files you can see the notes, and you can even modify them to suit your needs
geposted Tue 22 Nov 22 @ 11:08 am
@LOGODOG I'll try PhantomDeejay's guide first - thank you so much!
@PhantomDeejay - thank you so much for link to guide - I'll try...
geposted Tue 22 Nov 22 @ 2:21 pm
@LOGODOG
@PhantomDeejay
I managed to send a note to the DAW and the problem was in the (repeat_start_instant 'StartFunkyChase' 2000ms 2 toggle "$Chase1") command - it does not send a signal. With the custom button , the issue is solved by the (set '$Chase1' 1 while_pressed) command, but it is important for me to figure out the POI - how to make the ON command first, then OFF if repeat_start_instant doesn't work at all. I can't figure it out on my own( Please help!
@PhantomDeejay
geposted Wed 23 Nov 22 @ 8:32 am
repeat_start_instant 'StartFunkyChase' 2000ms 2 & toggle "$Chase1"
You forgot the &
geposted Wed 23 Nov 22 @ 8:58 am
@PhantomDeejay
POI send midi command as expected now!
I just copied all the commands from the very first post and didn't check the syntax.
Therefore, nothing worked out for me at the beginning - then I will add one post to the old topic so that it is clear what the error is.
The implementation of this scheme gives me invaluable help in conducting a theatrical performance. Many thanks to you guys for the tips and help!
All the best to you
All the best to you
geposted Wed 23 Nov 22 @ 5:00 pm
