Hello.
I would like to program a button on my Denon DN-S3700.
This should switch between player 1 and 3 on the left deck.
Unfortunately I can't get the job done.
Does anyone here know what the exact midi code is?
This would help me a lot.
Regards Rene
Regards Rene
geposted Sat 26 Nov 22 @ 8:43 pm
i use this (found from LOCODOG)
deck left invert_deck & deck left select
and/or
swap_decks 1 3
and/or
swap_decks 1 3
geposted Sun 27 Nov 22 @ 12:55 am
Unfortunately that is not the correct code.
I want to be able to control player 1 and player 3 on the left player.
I want to be able to control player 2 and 4 on the right player.
With the code you gave me, player 1 and player 3 change positions on the screen.
But unfortunately I can't control player 1 first and when I press the button I programmed to control player 3.
I hope you have some more suggestions or someone else.
Thanks for the effort.
geposted Sun 27 Nov 22 @ 11:05 pm
On which button?
And what?
left side
-----> swap_decks 1 3
right side
----->swap_decks 2 4
Maybe a picture of your settings under "MAPPING" will help...
And what?
left side
right side
geposted Mon 28 Nov 22 @ 12:55 am
sorry for the late response.
But It worked.
There are so many settings.
But it worked anyway.
It can be seen in the photo below.
You may not understand everything in terms of text in the photo.
That's because I'm from Holland and therefore my language on the computer is set to Dutch.
Thanks for your explanation.
But It worked.
geposted Mon 28 Nov 22 @ 11:12 pm
Nice.
The code is also on the right button.
geposted Mon 28 Nov 22 @ 11:32 pm
That's right.
I understood that.
Thanks again for your reply, it's all working fine now.
I understood that.
geposted Sat 03 Dec 22 @ 8:53 pm
