Topic: Virtual dj with pioneer SZ2 que problems
UreiPRO InfinityMember since 2007
Hi All
Looking for help ???
I’m using virtual dj with Pioneer SZ2. When I use 2 computers & switch from deck A & switch over to deck B I’m having que issues on headphones.
Thanks
geposted Sun 27 Nov 22 @ 6:57 pm
AsTheDJPRO InfinityMember since 2008
what I do is Plug up the controller GO through all your Channel volume up & Down (sliders) & then the Sampler volume LAST cue/headphone light the channel you going use, the light works opposite.heres my setting without the SZ-2 hook up
geposted Sun 27 Nov 22 @ 9:11 pm
Make sure its in external hardware mode for those separate channel settings. I found the sz2 is not a true hardware mixer UNLIKE the SZ and the RZ,, which are perfect for those settings. You may need to run the standard internal mixer mode setup (ASIO settings) and let virtual dj set your sound card.
geposted Tue 29 Nov 22 @ 4:22 am
SZ2 Does not offer alternative mixer modes.
It supports only this "hybrid" mode that uses the audio setup mentioned above and in the manual.
geposted Tue 29 Nov 22 @ 10:54 am
