I use VDJ on a Windows desktop and a MacBook.
I use a mix of actual music files and streaming music (Tidal)
Can someone suggest, or point me to info, as to the best way of going from on device to the other and duplicating the playlists, virtual folders and music files between the two so that changes and edits made on one device, are moved to the other, including cut points etc?
I'm getting confused about the main database backup vs the databases that exist at the root of disk volumes etc.
Many thanks
Many thanks
geposted Fri 02 Dec 22 @ 12:54 pm
