I've just put VDJ on a Surface Go tablet as a backup device. It all works perfectly well, but I can't seem to drag files from the browser onto a deck.
Is there a setting I need to enable for dragging on a touchscreen? Or is there a quicker way of loading a file onto a deck other than "press and hold, select Load On, select Deck".
geposted Sat 03 Dec 22 @ 9:56 pm
search in options for
-----> "touchScreenMode"
-----> "multiTouchTwoFingerScroll"
(and/or use a skin for touchscreen)
geposted Sun 04 Dec 22 @ 10:04 pm
dont forget that surface don’t have a fan like a computer, that surface can keep up but not along time without over heating.
geposted Mon 05 Dec 22 @ 12:32 am
Thad did it. Thank you!
geposted Sat 10 Dec 22 @ 12:22 pm
I was wondering. I'll do a few at-home tests to see how it goes. I'm a fairly low cpu user though as most of what I do involves no mixing and no stems, so I should get a while out of it I hope.
geposted Sun 11 Dec 22 @ 8:18 am
