ive just downloaded the latest version of vdj and its saying i need modern hardware to use stems properly, this is really confusing as im running a ryzen 5800x3d and an rx 6700xt nitro plus with 32 gig of ram. why is it flagging that my hardware is old? is it an amd issue like i have seen in some older forums about mac/ if so any idea either how to fix this or a timeline for when it will be fixed?
geposted Mon 05 Dec 22 @ 4:14 pm
should be fixed already:
https://virtualdj.com/download/pc64/earlyaccess
geposted Mon 05 Dec 22 @ 4:29 pm
thank you so much. was weird as id literally just updated from the start screen prompt. would have thoiught that would have been the latest version
geposted Mon 05 Dec 22 @ 4:46 pm
are AMD cards working seamlessly with Stems 2.0? VDJ keep on saying you need a NVidia card, but other powerful GPU's should work as well, right?
geposted Mon 05 Dec 22 @ 6:38 pm
it works faster with a nvidia, but a amd rx or intel arc will still work ok
geposted Mon 05 Dec 22 @ 7:00 pm
