HI,
I'v analysed all my library, and all .vdjstems are ok and same directory.
But if i rebuilt my database, and scan my SSD, .vdjstems are ok and still here, if i play them but they don't show as .vdjstems in prepared stems.
i've try batch and reload tags : no - analyse -> idem
can you add in options in this batch menu ? :
Add to batch "find existing stems"
(to add in prepared stems list and that can be retrieved by filter stems exist...)
they are marked as prepared stems if i play it, but for the non played after Database rebuilt they are listed as non stemms, even if .vdjstems already exist;...
Regards,
Olivier
Regards,
Olivier
geposted Thu 08 Dec 22 @ 4:38 am
geposted Thu 08 Dec 22 @ 4:41 am
just open the folder in vdj and it will automatically fix the vdjstems icons for all the files in that folder.
note: only vdjstems created with stems2.0 have the icon. if you have old vdjstems files from vdj2021, they will not have the icon and that’s by design.
they will still show up in the stems/prepared folder though (without icon).
geposted Thu 08 Dec 22 @ 8:47 am
