I'm looking for a solution to maintain the sorting of a playlist ordered for example by "Key" when closing/opening the program.
if I order a playlist by Key I end up with this situation, but if I change the ordering of the pieces due to set requirements, the next time I reopen the program I find the playlist no longer ordered as I left it before closing.
I can't find a solution, the only one that came to my mind is the possibility to change the numbering of the "order" column and then renumber according to the current ordering.
There are 2 questions: how do you keep the order that I changed when exiting the program, or how do you change the "order" column to the sequence I want?
geposted Fri 09 Dec 22 @ 10:05 am
a playlist is an ordered list, really if you want ordered by key you want a virtualfolder [a collection, not a list]
geposted Fri 09 Dec 22 @ 3:19 pm
