Hey folks,
I'm now wondering for months how to make my beginners life a bit easier.
When dancefloor is burning and the massive in good mood, I love to do some rewinds/pullups/backspins from time to time.
Therefore I reduce the volume a bit and active some fx manually. When the backspin is finished and the track is playing "normally", I have to bring both adjustments back to its previous condition.
Sometimes I forget to do so which ends up in unwanted sound waste.
So I tried to solve this issue with some scripting - unfortunately without success.
Is it possible to write some code that detects, if a song is played backwards and then f.e. deactivates fx in the moment, the song is running normal again?
Thanks for any hints or examples!!!
greg
greg
geposted Fri 09 Dec 22 @ 10:13 am
repeat_start 'CatchSpin' ? on & repeat_stop 'CatchSpin' : off & set 'howMany' 0 & set 'trackT' `get_time 'elapsed' 44100` & repeat_start 'CatchSpin' 25ms & param_bigger "get_time 'elapsed' 44100" "get_var 'trackT'" ? set 'trackT' `get_time 'elapsed' 44100` & var 'howMany' 2 ? gain -22% & cycle 'howMany' 1000 & effect_button 'echo' 2 1 & effect_active "echo" & set 'beatvar' `get_bpm & param_1_x & param_multiply 60000` & get_var 'beatvar' & param_cast "ms" & repeat_start 'rsiOnebeat' & effect_active 'echo' off & pause & repeat_stop 'rsiOnebeat' : cycle 'howMany' 1000 : set 'trackT' `get_time 'elapsed' 44100` & var_smaller 'howMany' 3 ? set 'howMany' 0 : gain +22% & set 'howMany' 0
Try this
geposted Fri 09 Dec 22 @ 1:09 pm
locodog wrote :
Try this
Holy ***, thanks locodog for this example!
One more question to this: So far I only have some experience in adding code to a specific trigger (button/knob) in the controller mapper.
Where do I have to put your snippet? Is there an action needed to activate the desired behavior?
Sorry for that noob question!
Cheers
Greg
EDIT: I added the code to a custom button and something is happening! So I'll play around with that. THANK YOU!
geposted Fri 09 Dec 22 @ 2:17 pm
Hi Locodog,
tried it yesterday - it works fine! Thank you very much!!!
Cheers
Greg
Cheers
Greg
geposted Tue 13 Dec 22 @ 6:37 am
