I'm using the DDJ-800 and trying to figure out how to map one of my Pad FX pads to fade out instead of abruptly ending the effect when I click on it. I have this pad set to stem_pad 'acapella' (to isolate the vocals for tracks) and I'm looking to find a way to have the instrumental fade back into the mix, rather than instantly. This obviously involves finding a way to fade out the effect when I pressure press on the pad, but I can't find a solution. I'm trying to do this without mapping/utilizing any knobs if possible. Any help would be appreciated!
geposted Fri 09 Dec 22 @ 12:04 pm
Rather than use the pads to switch stems parts on/off, you can use the EQ knobs to fade them in/out.
geposted Fri 09 Dec 22 @ 1:35 pm
groovindj wrote :
Yeah, I'm aware of that, I would just rather not deal with switching back and forth between stems and eq if I can just do it with a pad.Rather than use the pads to switch stems parts on/off, you can use the EQ knobs to fade them in/out.
geposted Fri 09 Dec 22 @ 10:35 pm
