I have a question about the precomputed stem. If your songs/tracks have precomputed stems with VirtualDJ 2021, do you have to precompute stems again with VirtualDJ 2023?
Yes or No
If yes the VirtualDJ 2023 is really slow computing stem. Thanks!
Yes or No
geposted Fri 09 Dec 22 @ 11:20 pm
For using Stems with the best quality "STEM 2.0" you must reprepare your tracks. The quality of Stems 2.0 is so much better than the 1 Version. And good things need time ;) and Power.
geposted Fri 09 Dec 22 @ 11:32 pm
Thanks for responding but If I am using the new generation of intel 7 and an SSD drive for windows 11, I think it should be faster or equal to version 1, but this is very very slow.
geposted Fri 09 Dec 22 @ 11:47 pm
