Hello, I would like to program 2 bottons on my pad. First, when I push it, I would like to just play the stem instrumental and loop 8 beats and I would like another one When I push it to play accapella and loop 8 beats. Please help me. No idea how to do it. Thank you
geposted Sat 10 Dec 22 @ 4:19 am
loop 8 & stem_pad 'instrumental'
loop 8 & stem_pad 'acapella'
geposted Sat 10 Dec 22 @ 8:40 am
thank you
geposted Sat 10 Dec 22 @ 4:20 pm
Hi, i have an other idea.
this fist version is not so cool when only on of booth (loop or PAD) is on.
select your favorite choice :)
when loop on or pad on, turn the other on:
when only loop on turn loop off / when only PAD on turn Pad off.
(loop ? set loopon 1 : set loopon 0) &
(stem_pad 'instrumental' ? set inson 1 : set inson 0) &
(var_equal loopon 1 ? var_equal inson 1 ? loop & stem_pad 'instrumental') &
(var_equal loopon 0 ? var_equal inson 0 ? loop 8 & stem_pad 'instrumental') &
(var_equal loopon 0 ? var_equal inson 1 ? loop) &
(var_equal loopon 1 ? var_equal inson 0 ? stem_pad 'instrumental')
(stem_pad 'acapella' ? set acon 1 : set acon 0) &
(var_equal loopon 1 ? var_equal acon 1 ? loop & stem_pad 'acapella') &
(var_equal loopon 0 ? var_equal acon 0 ? loop 8 & stem_pad 'acapella') &
(var_equal loopon 0 ? var_equal acon 1 ? loop) &
(var_equal loopon 1 ? var_equal acon 0 ? stem_pad 'acapella')
(var_equal loopon 1 ? var_equal inson 0 ? loop) &
(var_equal loopon 0 ? var_equal inson 1 ? stem_pad 'instrumental')
(var_equal loopon 1 ? var_equal acon 0 ? loop) &
(var_equal loopon 0 ? var_equal acon 1 ? stem_pad 'acapella')
geposted Sat 10 Dec 22 @ 5:15 pm
