Hi guys. I mapped 4 controller sliders to get continuous control over rhythm / bass / instru / vocal. Here is my original mapping:
<map value="GROUP_SL_1" action="stem "rhythm""/>
<map value="GROUP_SL_2" action="stem "bass""/>
<map value="GROUP_SL_3" action="stem "instru""/>
<map value="GROUP_SL_4" action="stem "vocal""/>
Now, each individual Stem volume goes from 0-100% with the faders between 0-50% (0.0-0.5 input). Anything between 50%-100% on the faders (0.5-1.0 input) overdrive each Stems, as if the "nominal" level for a Stem was originally 50% of the value. Here is my workaround, but unless I missed something, I don't think I should need to do it:
<map value="GROUP_SL_1" action="param_multiply 0.5 & stem "rhythm""/>
<map value="GROUP_SL_2" action="param_multiply 0.5 & stem "bass""/>
<map value="GROUP_SL_3" action="param_multiply 0.5 & stem "instru""/>
<map value="GROUP_SL_4" action="param_multiply 0.5 & stem "vocal""/>
I also tried on several controllers and they all trigger the same behaviour, as all pots / sliders ranges from 0.0 to 1.0.
Cheers :-)
Cheers :-)
geposted Sat 10 Dec 22 @ 2:34 pm
Am I the only one who mapped pots and/or sliders on STEMS ? Anyone else also noticed that ?
geposted Sat 17 Dec 22 @ 7:41 pm
I believe the majority is using Stems with Pads or EQ knobs. You correctly found that if you dont want boosting a Stem and avoid distortion, limiter etc, you need to either not exceed 50% (same as if you are using EQ knobs) or add a param_multiply 0.5
In a future update there may be a new action for such cases, but it will be just a simplified version of what you already found.
geposted Sun 18 Dec 22 @ 12:21 am
Interessting! What I want to archive:
On a knob I want to have just the Vocals on Position 0. Everything in on Position 50. And on 100 I want to have everything in but the Vocals.
Any hints how to Script that knob?
Cheers
Cheers
geposted Sun 18 Dec 22 @ 12:35 pm
Try ..
param_smaller 50% ? stem 'Rhythm' & stem 'Melody' & stem 'Vocals' 50% : stem 'Rhythm' 50% & stem 'Melody' 50% & param_invert & stem 'Vocal'
geposted Sun 18 Dec 22 @ 2:27 pm
Cheers
Cheers
That is what the filter knob does currently, if sound color fx is set to vocal
So for thet the script is simply
Filter
_and then you of course need to make sure that the sound color effect is set to vocal
The way I read it, he wants it to work in reverse - instrumental when turned clockwise, acca when turned anti-clockwise.
geposted Sun 18 Dec 22 @ 2:52 pm
Thanks you all. I will try the script and the way with the mentioned "filter / color fx" and see what works better for me.
Many thanks!!
Many thanks!!
geposted Sun 18 Dec 22 @ 3:39 pm
