I am currently running a Windows laptop connected to a DDJ RZ and have been getting occasional audio dropouts for a while. usually they last like 3 seconds and happen every two hours. I checked the VDJ log today and it is also showing my max frame rate was 48 it was set to 60. When not processing stems my graphics card use sits at a consistent 5%. I have DXVA disabled because when it is on the current playing video flashes upon loading another track. Have tried both high and medium quality with video processing. My computer specs are shown below (I am not using the RADEON card for video because if I do there is a huge amount of tearing)
Processor AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx 2.30 GHz
Installed RAM 16.0 GB (15.4 GB usable)
Graphics NIVIDIA RTX 2060 6.0 GB
Any help with these problems would be much appreciated (I had these same issues before STEMS 2.0 they have not gotten any better or worse)
geposted Tue 13 Dec 22 @ 2:37 am
Did you update the drivers for the rtx?
geposted Tue 13 Dec 22 @ 4:47 am
Yeah my rtx version came out this month.
geposted Tue 13 Dec 22 @ 5:53 am
Today i set v sync to controlled by application (it was set to fast) and had no glitches with video set to high and 60fps. If tonight is anything to go by I think i may have found the issue
geposted Wed 14 Dec 22 @ 10:30 am
