Topic: get_status script
would love learn more about the ........ get_status script.
Dennyo asked about get_status script
here:
https://virtualdj.com/forums/249140/VirtualDJ_Technical_Support/With_Stems_2_0_analysis_is_now_much_slower__Analysis_options_removed_.html?page=4
maybe asked in wrong thread, but never answered.
Does get_status have optional parameters, to specify displayed output?
would love any of 3 things, if any are possible:
1) a way to get the percent of stems separation, without holding mouse over button to get tooltip info.
the tool tip displays the percent for stems separation, but the displayed get_status does not show percents.. it displays "Computing stems deck 2"
while the tooltip will show: "Computing stems deck 2 (56%)"
Is there a way of getting the percent (separately), or having it also apart of the displayed status?
2) If it could output on multiple lines so it could fit into a given width. (since it could be displaying: Computing stems deck 1 Computing stems deck 2 Computing stems deck 3 etc.... very long)
3) or a way, to get deck specific info
deck 1 get_status does NOT work
hopefully some of these may be possible.
win 10
7388
geposted Thu 15 Dec 22 @ 7:40 am
+1
It's not really relevant if stems separation has finished
It's more relevant if stems are ready
And that you can easily script with has_stems
For instance
`has_stems 'ready'`
.. to put a tick on a button or in a skin
