Sometimes on my Deck Display the TAP & EDIT Buttons disappear. When that happens, how to I bring them back? Sometimes deck A will have them, and B will not. Sometimes both decks will be missing them. Thanks.
geposted Fri 16 Dec 22 @ 4:31 pm
Are you using the default Pro layout skin ? If so, click on the BPM value (Nr.5 https://www.virtualdj.com/manuals/virtualdj/interface/decks/trackinfo.html#pro ) to show/hide the BPM edit panel
geposted Fri 16 Dec 22 @ 7:37 pm
Got it.
Thank you
Thank you
geposted Fri 16 Dec 22 @ 8:00 pm
