my Hybrid 1310 controller only maps to Vitrual DJ 8.
The other day the software updated and now controllers wont map, please can you give ma link to download VDJ 8 please
geposted Sat 17 Dec 22 @ 5:03 am
ill try i just sent link but dont work so edit this post
geposted Sat 17 Dec 22 @ 7:51 am
All controllers supported in 8.0 are still supported in 2023.
What shows up exactly in the controllers tab in options?
geposted Sat 17 Dec 22 @ 9:07 am
controllers are dead, program doesnt find them.
Supplier also said to me when i got them that they will only map to 8
geposted Sat 17 Dec 22 @ 11:18 am
If not even a simple midi device shows up in 2023, then it won't show up in any version of VDJ 8 either.
There's no difference in the controller detection between 8 and 2023
Does the controller show up in Device Manager?
geposted Sat 17 Dec 22 @ 11:20 am
