Topic: Virtual DJ & XDJ-XZ Channel Sync Issue
Hi Folks,
I love VDJ, and I recently purchased an XZD-XZ to train for clubs and festivals!
However, I've noticed a terrible recurring sync issue between the XDJ and VDJ.. The volume for Channel 2 comes out of Channel 1, even through I Linked everything correctly, as far as I can tell.
In order to get it properly synced, I have to do it "just so," and often reboot the software and VDJ until is just works.. I have to go into the settings every time I reboot either, and just click through it (I don't change any settings), only for it to tell me changes are about to be applied, when I go to X out! But as long as I do this before I begin playing music on a channel, I have about a 45% chance of it working.. :(
Has anyone else experienced this issue?
geposted Wed 21 Dec 22 @ 5:06 am
Probably will help if you can post a picture of the audio setup in VDJ before you change anything. (not that you are by the sounds of it)
Do all the other channel faders work as expected?
Is it loading the track on deck 3? so hence the sound is coming out of channel 1, which would be expected.
geposted Wed 21 Dec 22 @ 9:23 am
geposted Thu 22 Dec 22 @ 6:44 am
