I may be being very dumb here and tell me if I am, however...
I have two four deck controllers and I have connected to VDJ and all works fine but what I am trying to do is control 4 decks individually and if I press the deck select button it changes the decks for both controllers - obviously. So my question is - Is there a setting to stop the deck select buttons from controlling both decks ?
The reason for trying this is so I can control 4 decks independently rather than having to press the deck select button
Cheers James
Cheers James
geposted Wed 21 Dec 22 @ 8:12 pm
No you'd need to remap to do this cleanly, it also depends on your controllers
geposted Wed 21 Dec 22 @ 8:16 pm
I have a prime 4 and a Traktor S3
geposted Wed 21 Dec 22 @ 8:27 pm
Well it'd be the s3 I'd remap, you've got your left/right-deck buttons that's where your issue starts.
lots of remapping of the common elements like so.
device_side 'left' ? deck 3 action : deck 4 action
you'd probably be somewhere close.
geposted Wed 21 Dec 22 @ 10:01 pm
Before I attempt remapping, if I used the 99deck skin is there an option to assign channels to decks ?
geposted Thu 22 Dec 22 @ 7:14 am
theoretically yes, realistically no. every single mapping entry would be a huge 100 query script.
I wouldn't even consider it without definition files for all devices.
geposted Thu 22 Dec 22 @ 9:24 am
Thanks for your replies ! I've connected my 2 channel controller along side my prime 4, changed some settings and a bit of mapping and all is well thankfully ! So much more fun having four individual decks !
geposted Thu 22 Dec 22 @ 8:30 pm
Perhaps could use assign_controller and avoid remapping.
So try to put deck 3 assign_controller to the ONINIT key of the S3
geposted Fri 23 Dec 22 @ 4:40 am
hello i have a little probleme using the 4 decks default skin pro in vdj 8.5.
its when i push play button it only play deck 1 even if i choose deck 3 for ex. it just happen with this skin all 4 decks for ex vdj 7,8 works good but in the 8.5 no
im using numark mixtrack pro fx. thank you for reply
geposted Wed 06 Aug 25 @ 6:24 pm
