Hello,
i have just purchased the pro version in order to have my controler to give me the ability to launch samples.
But with launchpad pro , nothing work : can i do something with custom mode or anyhing eles ein mapping ?
geposted Sat 24 Dec 22 @ 10:45 am
Have you explored the setup and configuration, in the manual:
https://virtualdj.com/manuals/hardware/novation/launchpadpro.html
Also make sure your controller is one of the 4 Novation Launchpads supported by VDJ.
The Launchpad Mini MK3, Lanchpad MKII, Lanchpad Pro, and Lanchpad X are supported.
It is possible that the Lanchpad Pro MK3 a newer version is not yet supported. (as the photo of the supported Lanchpad Pro appears different from the Lanchpad Pro MK3, which also has the newer firmware v1.2)
That can be answered by DJDAD, if it is currently, or will be supported.
geposted Sat 24 Dec 22 @ 11:53 am
hello,
this model seems not be in the list (huge list ;-))
BUT : can i try to work on mapping ? (and share it)
is there a tutorial or documentation for that ?
geposted Sat 24 Dec 22 @ 2:02 pm
Yes, most likely the MK3 is a different type of device and not supported as plug n play.
You can try yourself https://virtualdj.com/wiki/Controller%20Developers.html but the Launchpads are a bit tricky in Mapping, if you havent created a Definition file in the past it will be hard for you. Perhaps we could assist and arrange Teamviewer sessions after New Year's.
geposted Sat 24 Dec 22 @ 4:32 pm
I am in that same pickle with my LaunchKey mk3. I tried to navigate creating the definition xml, but there’s a reason I’m a dj and not a programmer…😂
geposted Sat 24 Dec 22 @ 6:50 pm
If as you say, you have just purchased it, and during the holiday season, you most likely have the opportunity to return it and consider getting, one of the currently supported Lanchpad versions, if it would also work for you intended use.
That may be the much easier path.
geposted Sat 24 Dec 22 @ 9:19 pm
your right i wil l give it a try next years.
geposted Mon 26 Dec 22 @ 10:54 am
I'm waiting for this too ;)
geposted Sun 12 Feb 23 @ 8:27 pm
me too !! i have this controller and not having official support for mapping in Virtual DJ
sad :'(
sad :'(
geposted Fri 27 Oct 23 @ 6:07 pm
