Hi guys,
I am developing a MIDI controller. Is there any way to obtain waveform data by using the VDJScript? I used the get_gemini_waveform and get_numark_waveform verbs to get it. I received a small amount of waveform with get_gemini_waveform. And I could not get a piece of meaningful information from get_numark_waveform.
geposted Mon 26 Dec 22 @ 11:39 am
I am afraid we cannot share confidential information.
geposted Mon 26 Dec 22 @ 1:20 pm
Just so that it doesn't sound that we are trying to turn you off:
Those actions you mentioned are designed to send MIDI or HID data in a way particular devices understand (like some Gemini or some Numark controllers).
Since the data follow the formatting that those controllers expect, and that formatting is not publicly disclosed, we cannot share it.
geposted Tue 27 Dec 22 @ 12:19 am
