I just notice static sound popping frequently while scratching back n forth the jog wheel.
But the issue is gone if I set jogSensitivityBend value to '0'!
But we already know we need this function for beat matching and some stuffs..
Tested with Brand new CDJ 2000nxs2, XDJ-XZ & DDJ SB3 and definitely sure it is not hardware issues!
(VDJ v8.5-64 b7131)
footage 🔻🔻🔻
https://youtu.be/aFBHc-a_M1Y
(VDJ v8.5-64 b7131)
footage 🔻🔻🔻
geposted Fri 30 Dec 22 @ 8:27 am
This is an old build from back in September Definitely should’ve updated since then especially since BUILD 7183 (2022-10-20)
provided performance improvements when using Pioneer CDJs…
geposted Sat 31 Dec 22 @ 1:20 am
Also of note Home Users can't use the software with controllers for more than 10 minutes.
geposted Sat 31 Dec 22 @ 1:23 am
I just updated newer and latest versions tho,still the issue persist..
Also tried clean uninstallation of previous version and re-installed latest but nothing's helped!
geposted Sat 31 Dec 22 @ 8:05 am
So......who's AZIN?
geposted Sat 31 Dec 22 @ 3:06 pm
"So......who's AZIN?"
geposted Sat 31 Dec 22 @ 9:54 pm
Azin? That was the cracked version he used rather than using the subscription or 30 day full version trial. There has never been any full detail of what his system is but after using any crack that often is the issue...
geposted Sat 31 Dec 22 @ 10:00 pm
Yes my bad I thought that was piracy issue i just tested on my old pc but also on my new Huawei D14 notebook with official freeware trial 2023 version,this issue persist too!
Optimized PC for DJ Programs/DAWs and handling others well..Plus I turned off Stems feature too!
Specs :
Intel Core i3-10110U processor | 8GB RAM DDR4| 256GB NVMe PCIe SSD | Integrated Intel UHD Graphics 620 | Windows 11 Pro
Specs :
geposted Mon 02 Jan 23 @ 6:48 am
geposted Mon 02 Jan 23 @ 9:24 am
Ok so now,I tried ur latest free version on Another new PC with i5 10th Gen,GTX 1050Ti,12Gb Ram DDR4 and Windows 10 Pro this time!
But always the same..😶
geposted Mon 02 Jan 23 @ 12:15 pm
