Hi there,
I have a Hercules DJInstinct Controller which is not working where if I adjust the fade it shows a ghost of where the slider is and the actual slider bar that is in the screen remains in place.
I have tried the controller with another DJing software and it works fine on there.
The scratch turntables do not respond either or any other control.
Please help if you know what may be causing this?
Thanks
Alex
Thanks
Alex
geposted Fri 30 Dec 22 @ 12:41 pm
I have the same poblem with an mp3e2 controller on a pc win 11 and vdj 2023. Also doesn't work with vdj 2020 32 bits on win 11. OK under win 8.
A solution. Note that i 've updated the drivers for win 11 but nothing goes on
geposted Fri 30 Dec 22 @ 1:16 pm
my virtual speeds up whilst playing with hercules impact
geposted Fri 30 Dec 22 @ 5:08 pm
