Topic: VDJ EQ "EZ mode" not working
Hi my VDJ works for the new stems on EZ mode for the eqs for about 10 minutes and stops working and turns into the old style faders can anyone help
geposted Fri 30 Dec 22 @ 7:48 pm
What you are describing is .. Stems not being available (not being separated) And then NON of the stem features are there.. ie revert back to the standard EQs
geposted Fri 30 Dec 22 @ 8:41 pm
if your computer is too slow for real-time stems 2.0 you can drop the songs to the stems folder to prepare them in advance.
(and still use the older ultra fast stem 1.0 engine for songs that are not yet prepared, if you set stemsRealtime in settigs to "reduced quality")
geposted Fri 30 Dec 22 @ 11:48 pm
