Hello All
I can't seem to find where to change what is effected in Effect Stems in STEMS 2.0. When I apply it to the pads, there doesn't seem to be a xml file like the ones you can download to the pads folder.
All I want to do is change FX: Melody from = Bass+Instru to = Instru
Is this possible?
Is this possible?
geposted Fri 30 Dec 22 @ 9:29 pm
