Hello all !
I'm starting some scripting with VDJ but locking on variable use with action on deck
An concrete example :
Using automix dualdeck i have deck 1 playing track, and second waiting for playing.
Automix duration equal to 10s
When deck 1 hit a "action" POI it will set deck 2 eq_low to 0% that ok an working fine.
But here i start another action POI in same time and tell him to wait for 5 seconds and execute a loop to incrementing eq_low progressively to 50%.
For the repeat to 0% to 50% of eq_low i have used the following logic :
This part working fine but executed on current deck.
Objective is to perform the repeat on opposite deck, the conditional i use for get opposite deck
That was working fine too.
But when i want to execute some code like that
How i can tell him to use for example a defined variable ?
Here an example in video for more concrete
https://www.youtube.com/watch?v=cCeRE-Ead_o
Track have some POI (FADE_IN_START, AUTOMIX_START)
Actually :
- FADE_IN_START is where "automix" fadeStart POI is set, on this specific POI i adding action for increasing progressively eq_low that working fine in most cases but not at all.
- AUTOMIX_START is shot when track go the end when hitted it just starting the fade transition like normal, but opposite deck eq_low was set to 0% and setting an auto decreasing on eq_low for that deck with offset on POI depending on automix_length for lunch action not directly when fading started
That cool ! But when FADE_IN_START is not hitted when fading, no action start and is not very precise instead of AUTOMIX_START
Thanks for who want to help me !
Happy New Year :D
repeat_start_instant 'eqlat' 25ms & eq_low_freq & param_smaller 0.50 ? eq_low_freq +1% : repeat_stop 'eqlat'
deck 1 param_equal get_activedeck 1 ? deck 2 eq_low_freq 0% : deck 1 eq_low_freq 0%
set '$oppoDeck' `deck 1 param_equal get_activedeck 1 ? 2 : 1` & deck '$oppoDeck' eq_low_freq 0%
Actually :
Happy New Year :D
geposted Sat 31 Dec 22 @ 3:26 am
action_deck 1 ? deck 2 eq_low_freq 0% : deck 1 eq_low_freq 0%
can't use a variable as a param with the deck script, I can see the use but it doesn't exist, you've got to query something
geposted Sat 31 Dec 22 @ 3:37 am
Hey thank for the fast answer !
Ya didn't get working with param for now...
action_deck is like an alias for this long code, finally
But after some inspection on detail on VDJ, selected deck is set when loading file ! that following code not working !
But with magic of action_deck that seem to work with following
Will test more for sure but that sound cool thank for helping :D
repeat_start_instant 'eqlata' 25ms & action_deck 1 ? deck 2 eq_low_freq & param_smaller 0.50 ? deck 2 eq_low_freq +1% : repeat_stop 'eqlat' : deck 1 eq_low_freq & param_smaller 0.50 ? deck 1 eq_low_freq +1% : repeat_stop 'eqlat'
geposted Sat 31 Dec 22 @ 4:15 am
select & deck active select & deck default eq_low_freq 0%
If you don't mind selected deck being manipulated you could do this
geposted Sat 31 Dec 22 @ 4:57 am
