Topic: Effects for Decks 3/4
shootdajPRO SubscriberMember since 2005
I cannot seem to get effects working for Decks 3 and 4. Is this not possible in VirtualDJ? I'm trying to assign a controller mapping to it but it doesn't do anything.
geposted Thu 05 Jan 23 @ 7:53 pm
deck 3 effect_active 1
etc
geposted Thu 05 Jan 23 @ 8:24 pm
Thanks, I had a bug in my code, but now it's working.
On another note, is there any way to show the effect panel for deck 3 and 4 in the Pro mode?
geposted Thu 05 Jan 23 @ 8:40 pm
etc
Where do I have to put this? Pls explain
geposted Thu 05 Jan 23 @ 9:47 pm
@HOUSEFROIND - The command needs to be put in the mappers section under Config. Select a button or slider or something and add it to its mapping.
@LOCODOG - could you please answer how to make the effect panel for deck 3 and 4 visible in the Pro mode? Is that even supported? Thanks
geposted Fri 06 Jan 23 @ 2:23 pm
