Hey support team,
I am a fan of pre-processing the stems. I have an i5 with 4 cores at 2.1 Ghz
Will more CPU cores pre-calculate the stems significantly faster?
Will more CPU cores make VDJ better when using many features of VDJ like more than two effects etc
I only want to be sure before I invest in a new PC
Thanks
Tom
Thanks
Tom
geposted Thu 05 Jan 23 @ 8:08 pm
Hello,
Steams need a gpu like geforce rtx.
The cpu is to slow, then u only can pre analyse the stem and save it.
But if u want to buy a new pc, then look for a gaming-laptop with 3070 and a high tdp power.
I buy a cheap legion L5 on BF sale over OTTO, with an 3050Ti, this is to slow after a few hours while parallel using shaders and daslight.
So i wait for the new generation with 4070, is maybe in april available in germany.
Then i think there be no problems with stems.
For more informations we can writ in german over pm.
geposted Fri 06 Jan 23 @ 12:08 pm
Thanks for your answer!
My question was if the pre analysis of stems is done by CPU? If yes will a new PC with more CPU cores be faster in pre-analysing. I don’t want to do it live, a GPU for over 1000 Euros is too much for my budget.
geposted Fri 06 Jan 23 @ 5:52 pm
Both are quicker on GPU. They can be done on CPU but in general take longer.
geposted Fri 06 Jan 23 @ 6:52 pm
If you don't have a suitable GPU, it will indeed be done on CPU, and a faster CPU with more cores will indeed be faster than a slower CPU with less cores.
geposted Fri 06 Jan 23 @ 7:31 pm
Thanks guys! That answers my question!
Happy weekend
Happy weekend
geposted Fri 06 Jan 23 @ 8:31 pm
